How do you check MTU Size??
clifford_ray_se
We are currently using an SCG200, and we are using the Default Tunnel Profile, upon checking the manual it is configured as MTU AUTO or we can manually configure it between 850-1500. Our client is asking if we have a way to check the MTU size?
7 REPLIES 7
Ankush_Chandan
RUCKUS Team Member
Hi Clifford,
The calculation will be Eth + IP + UDP + Ruckus GRE : 14+20+8+16 =58 . This negotiates MTU to no more than 1440.
-Ankush
clifford_ray_se
Got it. Thank you very much.
Greg_WiGuy
Contributor II
@ankush_ankush , Is it possible to set the tunnel to not use UDP encapsulation for networks that dont need NAT traversal?
