How do I add a WLAN to a particular dataplane in vSZ?
In my vSZ, I have added two dataplanes and I want one WLAN to tunnel to one, the the other WLAN to tunnel to the other. I don't see anywhere where you select which dataplane to use. In the manual it says to go to Configuration --> Cluster Planes --> and then click on the name of the dataplane. But in my console, the Dataplane names are just text. I can't select the dataplane in the config mode.
I have already approved it and it appears as managed. I have created a Ruckus GRE profile. I created a WLAN and configured it to tunnel with the aforementioned Ruckus GRE. The AP zone also doesn't appear to have a place to select which dataplane to use although that is where I select the tunneling profile.
Thanks all,
-gns
0 REPLIES 0
