01-05-2025 11:29 PM
Hello
I use to Ruckus T750
I'm trying to change sz 6.1.2 -> unleash 200.16 on my T750 AP. <=== Is it possible?
Is there a way to patch it without initializing?
Thank you.
01-05-2025 11:48 PM
6.1.2 and 200.16 are the controller version, you can Factory Reset the AP >> Upgrade to standalone version (from below link) and then upgrade to 200.16.
https://support.ruckuswireless.com/software/3857-ruckus-solo-access-point-118-2-0-0-875-release-t750
01-06-2025 12:42 AM
Can this be done when the AP is joined to vsz?
Do I need to unconditionally initialize the joined AP?
and I need to upload the image afterwards?
Please tell me how to avoid initialization.
Thank you.
01-21-2025 08:20 AM
You need to initialise in order to run Unleashed.
02-02-2025 09:09 PM
I want to know how to change it without initializing.
Thank you.
