HELP!! I need root password to install VM Tools in virtual Smartzone
randy_reyens
We newly installed or transfer our Virtual Smartzone to a new Machine blade server. Our new server requires us to install VM tools to our VM’s to better optimize the performance
Anyone knows what is the root password of the VM for us to install the VMTools? I think its linux based. thanks
3 REPLIES 3
diego_garcia_de
Contributor III
The vsz is a closed appliance. You won't be able to install vmtools. On the other hand, if you're using the correct version of vsz for your HV it will have the proper virtual disk and network drivers and should also handle shutdown messages gracefully. In short you don't need VM tools in then. You already have the needed things in the appliance
randy_reyens
Image_ images_messages_5f91c453135b77e247a256f6_c7a8455990dde9d11288cb705b983a11_RackMultipart2019080534704odul-a9ae6572-4b7c-4b45-8f9f-ec7b0c0e1df5-213597695.JPG1564968537
this instructions shows up what should we do next? thanks
Image_ images_messages_5f91c453135b77e247a256f6_e4b1c6abcb66eeb7ee5b337ae989801a_RackMultipart2019080554787p6dk-2603a8a0-b405-44a4-ba06-c0b1a0aa01c3-27698286.JPG1564968643
The new deployed server is Sangfor HCI and requires to install Vmtools what should we do next?? thanks
You can't install them. Just ignore the message. Vsz is a closed appliance with no access to the underlying operating system.
