GOOD MORNING, HOW CAN I LOAD FIRMWARE WITH SSH TO AP R700.
joel_cortes_f8d
GOOD MORNING, HOW CAN I LOAD FIRMWARE WITH SSH TO AP R700. SINCE THE LOOKING DOES NOT START CORRECTLY. POWER LED KEEPS BLINKING. THE DEVICE ANSWERS ME (192.168.0.1) CORRECTLY BUT DOES NOT START THE SYSTEM. THANK YOU
5 REPLIES 5
andrew_giancol1
Contributor III
You can access the device via SSH or does it only ping. if power keeps blinking, you may need to open a support case. if you are able to access the device via SSH, perhaps you only need to enable http/https.
joel_cortes_f8d
It's true, I can login by ssh. I configure xxx: set http / https enable. but even so it does not allow me to administer it. only by ssh
andrew_giancol1
Contributor III
you've begun all of this after running 'set factory' then rebooting the device? What is the AP firmware?
david_black_594
Contributor III
Have you tried a factory reset? Press and hold 8+ seconds. After the reboot try to login with default credentials: super sp-admin
