External Captive Portal popup Once Connected to SSID without Typing any URL
pamuditha_abeys
Contributor
There is a requirement that when they connect to the SSID the captive portal will pop up immediately rather than waiting to type any URL through browser and a small delay in login the captive portal.
Is it possible to open external captive portal once I click connect to the SSID.
7 REPLIES 7
aleksandar_radi
Hi Igor,
I am talking about WISPr WLAN setting with external captive portal option.
pamuditha_abeys
Contributor
I am using WISPr WLAN with external portal. But no success.
I have tested using android device.
hrvoje_habljak
Hi all,
just got the same problem so I wondered has anybody made some progress about it.
To describe our specific problem. We have empty walled garden on WISPr WLAN setting beacuse we weren't able to remove any google related URL from previously set WISPr. So basicly, there is no google related issues I think.
And when we try to connect to that specific SSID, on Windows, iPhone and some Androids it pops up and redirects us to set web page. But on some Androids it doesn't work.
Some of solutions that I have found on web is to enable smart client and turn off https redirection, but that didn't help.
So if anyone has found some new solution, we would be grateful.
Thanks.
