I can see the advantage of using Channelfly, but what advantages or conditions are there for configuring the channels manually?
Here is a comment about the results of having common channel assignments on adjacent APs.
http://www.wireless-nets.com/resource...
"setting access points near each other to the same channel will degrade capacity, and performance will be significantly lower as traffic on the network increases. As a result, it’s best to assign non-overlapping channels to nearby access points."
When I set the channel assignment to auto I noticed several adjacent APs assigned to the same channel. If the above statement is true, how could the automatic assignments to the same channels result in better performance or connectivity? Wouldn't those 6 APs signals have an effect on each others signals as they would with any other AP?
I'm thinking that Channelfly may be useful under some, but not all environments. I think the same may be true for manual assignments too. Even though one channel setting may have little impact, I'm looking at all aspects of a wireless network. Number of APs, location/placement of APs, channel assignment, and any other configuration that will improve our guest network.
I get comments about slowness, disconnections, connectivity problems to name a few. My tests do not show these results, but I haven't yet tested during the peak hours between 10PM and midnight. I do my tests using multiple devices iPhone, iPad, laptops (OSX and Windows), I have done numerous speed tests, wireless survey, heat map, etc. So even though channel assignments seem less significant, I have to look at every aspect to narrow down these issues.
