Download firmware 3.1.2.0.150 for ZF7343
There is the possibility of loading a Ruckus ZF7343 AP firwmare 3.1.2.0.150 directly, to be discovered by the VSZ-H controller.
Thank you very much for the help
4 REPLIES 4
Esteemed Contributor II
No, you would load the Solo AP image, 100.1.0.0.432 which can connect to ZDs or SmartZone controllers.
Here's the link:  https://support.ruckuswireless.com/software/838-standalone-ap-software-100-1-0-0-432-indoor-aps
Thank you very much for the reply.
To connect an AP ZF7343 to the Virtual SmartZone High scale which image could be used? 100.1.0.0.432 Would serve us?
Yes, the 100.x Solo AP firmware can join a ZoneDirector or SmartZone controller.
