07-18-2017 04:37 AM
07-18-2017 03:52 PM
ruckus>enableMore about Smart Roam can be found in the following KB.
ruckus#config
ruckus(config)#wlan
ruckus(config-wlan)#smart-roam 3
ruckus(config-wlan)#exit
07-18-2017 11:02 PM
07-19-2017 06:26 PM
λ ssh [email protected]Hope this helps..!!!
Please login: admin
Password:
Welcome to Ruckus Unleashed Network Command Line Interface
ruckus> en
ruckus# config
You have all rights in this mode.
ruckus(config)# wlan test
The WLAN service 'test' has been loaded. To save the WLAN service, type 'end' or 'exit'.
ruckus(config-wlan)# smart-roam 3
The command was executed successfully. To save the changes, type 'end' or 'exit'.
ruckus(config-wlan)# exit
The WLAN service 'test' has been updated and saved.
Your changes have been saved.
ruckus(config)# exit
ruckus# show wlan name "test"
WLAN Service:
ID:
6:
NAME = test
Tx. Rate of Management Frame(2.4GHz) = 2.0Mbps
Tx. Rate of Management Frame(5GHz) = 6.0Mbps
Beacon Interval = 100ms
SSID = test
Description = test
Type = Standard Usage
Authentication = open
Encryption = wpa2
Algorithm = aes
Passphrase = test@123#
FT Roaming = Disabled
802.11k Neighbor report = Disabled
Web Authentication = Disabled
Authentication Server = Disabled
Called-Station-Id type = wlan-bssid
Tunnel Mode = Disabled
Background Scanning = Enabled
Max. Clients = 100
Isolation per AP = Disabled
Isolation across AP = Disabled
Zero-IT Activation = Disabled
Priority = High
Load Balancing = Disabled
Band Balancing = Disabled
Dynamic PSK = Disabled
Rate Limiting Uplink = Disabled
Rate Limiting Downlink = Disabled
Auto-Proxy configuration:
Status = Disabled
Inactivity Timeout:
Status = Enabled
Timeout = 1 Minutes
VLAN-ID = 1
Dynamic VLAN = Disabled
Closed System = Disabled
Https Redirection = Disabled
OFDM-Only State = Disabled
Multicast Filter State = Disabled
802.11d State = Enabled
Force DHCP State = Disabled
Force DHCP Timeout = 10
DHCP Option82:
Status = Disabled
Option82 sub-Option1 = Disabled
Option82 sub-Option2 = Disabled
Option82 sub-Option150 = Disabled
Option82 sub-Option151 = Disabled
Ignore unauthorized client statistic = Disabled
STA Info Extraction State = Enabled
BSS Minrate = Disabled
Call Admission Control State = Disabled
PMK Cache Timeout= 720 minutes
PMK Cache for Reconnect= Enabled
NAS-ID Type= wlan-bssid
Roaming Acct-Interim-Update= Disabled
PAP Message Authenticator = Enabled
Send EAP-Failure = Disabled
L2/MAC = No ACLS
L3/L4/IP Address = No ACLS
L3/L4/IPv6 Address = No ACLS
Precedence = Default
Proxy ARP = Disabled
Device Policy = No ACLS
Vlan Pool = No Pools
Role based Access Control Policy = Disabled
SmartRoam = Enabled Roam-factor = 3
White List = No ACLS
Application Visibility = disabled
Apply Policy Group = No_Denysruckus#
07-20-2017 07:29 PM
