Currently recommended firmware for vSZ
newsfool
I am about to deploy a new instance of vSZ with about 40 R610 APs.
The support section for vSZ downloads says the "recommended firmware" is 3.5.1 plus WPA2 Krack  patch. However, the latest available release is 3.6.1.0.227.
I'd rather not start a new instance with an older firmware version.
Is anyone using 3.6.1.0.227 in a production environment or know any good reason to avoid it for a new deployment?
Thanks.
6 REPLIES 6
paul_mcguire_20
Contributor
I am running 3.6.1.0.354 in my production environment.  The only issue is it falsely reports connection failures.  Other than that the latest firmware seems to works fine.
ryan_dougherty_
I have been running 3.6.1.0.227 for several weeks and haven't had any issues. I have 17x R610s. I didn't notice the connection failure issue that Paul is talking about on the AP firmware version that corresponds with the controller version (.227).
newsfool
Thank you, both! Sounds good.
brian_powers
Paul & Ryan,
I'm curious as if you're both using R610 of a few questions:
Are you also using 3.6 for the Zone firmware that is applied to the APs?
What is your 5 GHz channel width set to (if not auto)?
How many of your R610s selected a non-DFS (34-48 & 149-165) channel (if you're letting Channelization choose the channels for the APs).
