Converting standalone R710 to unleashed version at remote site
Hi, as the title says, I have a remote R710 I want to change to unleashed. Is it possible without a factory reset? I'd like to do this remotely if possible without user help?!
7 REPLIES 7
Hi Chris,
Long time Ruckus user here. What Abi and Paul said is indeed correct, but that should not be a problem if you have remote access to the Router/Gateway on-site. Here is why I say this.
After you firmware upgrade the WAP and it resets, it will grab an IP address from a DHCP server on the boot up. Just monitor your DHCP leases and you should be able to get back into it to configure it. Use port forwards or VPN to access it on the new IP address.
I have had it before where the WAP goes haywire and stops working during the setup remotely. Just have someone power cycle it on-site.
Hope this helps.
Cheers,
Alex
Alex,
This is exactly what I was looking for! Thanks much, that helps a lot.
Chris
sandeep_cheema
How to remotely configure url filtering ? I have R710 Ruckus device. Thanks
