07-07-2021 05:10 AM
Goodmorning,
I would to know if is possible to manage all my AccessPoints (there are 16 AP, model name "R600") from an only one dashboard.
Thanks.
Buongiorno,
Vorrei sapere se è possibile gestire tutti i miei AccessPoint (sono in tutto 16, modello "R600") da un'unica dashboard.
Grazie in anticipo.
07-07-2021 06:27 AM
Just note that the R600 is currently considered end of life, so once the https://support.ruckuswireless.com/software/3022-ruckus-unleashed-ap-200-7-10-202-127-mr-refresh6-so... software will be the last supported version of code on this access point.
On the positive, you won't ever need to do an upgrade! 🙂 Set it and forget it.
