Constant Power Cycle after upgrade to 200.9.10.4.202
r_v_7xpcziruizl
Ruckus R610 unleashed upgraded to latest firmware (200.9.10.4.202) yesterday, keeps power cycling constantly with no pattern.
I get the same message every time. No other reasons.
These are the messages on logs:
2020/10/01  16:38:51
High
AP[RAP@XXXXX] warm boot successfully, last reboot reason [power cycle detect].
2020/10/01  16:38:50
High
AP[RAP@XXXXXX] joins with uptime [182] s and last disconnected reason [AP Restart : power cycle detect]
13 REPLIES 13
Did you ever get this sorted out or did you have to downgrade? I've got an R510, R710 and R720 - experiencing the same problem on this firmware.  I just don't look forward to having to reprogram everything again by downgrading (the last time I did a backup and tried to restore, it didn't work at all).
nope. going through other threads similar to this, no real solution yet.
tony_heung
Contributor II
During the upgrade, I would usually set the "Preferred Master" before initiating the upgrade.  This helps to ensure the upgrade won't be confused while the existing master is rebooting and at the same swapping the master function to another pre-upgraded AP as master.
Sporadic reboots R610 Unleashed - Help Please!
Background:
-Have three R610's (latest unleashed firmware 200.9.10.4.212), all with wired connections. One is a master and the other two are adopted by this master (no mesh).
-Connect with full power using Ruckus power Bricks.
-All have been assigned static IPs and I have reserved the IPs in the router as well.
-The are all in the same management subnet vlan and SSIDs are assigned to 3 different vlans - works perfectly.
-I get all information logged through splunk.
Issues:
- Now and then the APs  reboot themselves - reason from the logs - "Heartbeat Lost"
- Both the Master and the adopted APs experience this on and off. Adopted APs more than the master slightly.
- When this reboot happens, the clients switch to the other APs, but it takes about a couple of minutes and is not smooth.
Question:
- What could be the reason for these heartbeat lost reboots? How do I fix it?
- This issue is causing a concern for reliability - Mostly has happened in non-active time windows for now, but can occur any time.
- I checked the router logs to see if there was any DHCP related issue - could not find any logs that point to it.
- I checked the AP logs to see any pattern, could not find any pattern, just the heartbeat lost and then reboots.
- Checked a few threads in the forums - have not got any concrete ways to fix this.
Conclusion:
- I am almost giving up on these great R610 to something more reliable - unless I find a fix for this.
I am an unleashed home user - I do not have support contracts.
Any help, pointers appreciated.
r_v_7xpcziruizl
Background:
Issues:
Question:
Conclusion:
