Checking Download Speed between R7363 and R710 with controller 1200
gautam_kumar_80
Can you explain what is the exact differences between R736 and R710. What will be exact throughput of R710 if we compare with R7363.
2 REPLIES 2
Esteemed Contributor II
Does it matter that the ZoneFlex 7363 2x2:2 mid-level 802.11b/g/n AP has been End of Sale since November 30, 2014?
It has a maximum throughput of about 300mbps using 40MHz channelization and 64-QAM on two spacial streams.
The R710 is our 4x4:4 802.11ac Wave2 top performance AP, with 80MHz channelization and 3 spacial streams, can
theoretically provide up to 1.2gbps.
If you have both model APs, you need to run at least version 9.12.x on your ZD1200.
john_d
Valued Contributor II
In addition to what Michael said, the R710 has a few generations newer radio chipsets / antenna designs, resulting in better sensitivity which translates to more range / higher throughput at a given range. I've noticed much better throughput even with legacy clients when I replaced an R700 with a R710, so it should be even more dramatic when comparing with a 7363
