Best way of configuring two R700 APs
peter_gram_7k4c
Just got my hands on two R700 AP's which I am planning on using to fully cover my house.
What is the best way of setting up two R700's, without having SmartZone or ZoneDirector?
Would be perfect if they could work together somehow, broadcasting the same SSID and handing off devices to eachother.. but I have a feeling that this wouldn't be possible.
Thanks a lot!
7 REPLIES 7
thomas_fankhaus
Contributor II
unleashed?
peter_gram_7k4c
unleashed not possible on R700 as far I as understand, so unfortunately not.
thomas_fankhaus
Contributor II
sorry, i thought of the R600.
then you only have the standalone version.
broadcasting the same ssid is still possible. but you have to configure each AP manually.
sunny_gupta
Contributor II
The R700 can be managed as: Standalone (not ideal for a pair), ZD (you could get a ZD1200), SZ, or Ruckus Cloud..  i recommend Cloud for this.  I have an R500/R700 set up under cloud for my house and it is stellar!  even if one goes down (because the cable is loose and got unplugged) I didn't even notice performance impact for days until i decided to reconnect.
