After WISPr authentication, Clients get redirected to https://scg.ruckuswireless.com:9998/SubscriberPortal/hotspotlogin
kevin_geil
Hi, I have configured IronWiFi as a WISPr authentication provider, and have a frustrating problem.  After entering the voucher code into the IronWifi site, the client gets immediately redirected to https://scg.ruckuswireless.com:9998/SubscriberPortal/hotspotlogin instead of the normal "you are now connected" page.  The scg.ruckuswireless.com page just has an "open network login page" which redirects back to the IronWiFi page, and repeats ad infinitum.   I have seen a couple of bad redirection posts in the forum, but not this symptom in particular.
I am using VszH and ZoneFlex R510 Aps.
As usual, any help will be greatly appreciated.
Thanks,
Kevin
2 REPLIES 2
eightohtwoeleve
Contributor III
Does IronWifi use POST parameters? If so, what are they set to?
michael_carty_7
Has there been any reply/ resolution on this? We are facing the same issue.
Labels
