03-18-2025 02:15 AM
03-10-2026 11:53 PM
I have a similar problem, and Ruckus refuses to fix it. I recommend looking at a different manufacturer.
03-12-2026 04:52 AM
Hey there, this was quite a while ago but interesting to see others have the same issue, I can update whats happened.
I discovered that our customer had with another distributor, purchased 2 new Zebra Handheld PDA devices. Around 8 of them was as a phone, android and used to scan products, and 2 others was more like an pad, larger which sits on the forklifts. Both was manufactured by Zebra.
I noticed in my tests that the restarting/crashes of the RUCKUS APs was caused by the handhelds. Tho interestingly, only by the Zebra Phones and not by the Zebra Pads, two different models.
The distributor for the zebra devices confirmed that do communicate a lot more aggressively, to make sure they have a very stable connection, and the Zebra Phone model was causing the crashes. I did a test where I walked around with the devices and I would notice crashes as it jumps between APs, but it only happened with Zebra Phones, not the Zebra Pads, not Laptops, not other regular phones, only that one.
Now, I understand RUCKUS choice not to fix it, this models are old and end-of-life, thats the nature of manufactures today. They did try on the support line but, the developers was just not allowed to push out any more firmwares.
I'm not sure who to blame, RUCKUS or Zebra, but perhaps Zebra as it was only one model causing issues of them crashing, or getting very unstable and it would lose packets and pings would be high as I roamed around.
The customer finally agreed reluctantly and understandbly, not happy with the new Zebra products causing issues, to swap out all the APs. We have around 15-20 APs, all was swapped out to newer RUCKUS R350, and the issues have been resolved after that.
