802.11R. Enabled?
mark_taylor_jd3
Hi folks,
1. Based on Ruckus' post about the KRACK vulnerability, the suggestion is that this is not enabled by default. But how would I check this?
We're using a Zone Director 3000 with zf7982 APs.
2. Is it only possible to get firmware updates if you have a support contract in place?
4 REPLIES 4
jakob_peterh_ns
Contributor II
1: Configure: WLANs: : Fast BSS Transition
2: Yes.
I don't see that as an option. Not sure if that's a good or bad thing!
Using firmware 9.7.1.0 build 17.
Not even implemented on that old firmware..
Even though that means you might have other old bugs in that firmware..
Type a product name
