7982's and HP 5406zl
Anyone encounter any issues when uplinking a Ruckus 7982 to a PoE enabled 5406zl Copper module. There is plenty of power availabe but all I get in the logs is the following:
I 09/06/08 22:12:17 00565 ports: port A11 PD Removed.
I 09/06/08 22:12:03 00561 ports: port A11 Applying Power to PD.
I 09/06/08 22:12:03 00560 ports: port A11 PD Detected.
I 09/06/08 22:12:00 00565 ports: port A11 PD Removed.
I 09/06/08 22:11:38 00561 ports: port A11 Applying Power to PD.
I 09/06/08 22:11:38 00560 ports: port A11 PD Detected.
I 09/06/08 22:11:34 00565 ports: port A11 PD Removed.
I 09/06/08 22:11:16 00561 ports: port A11 Applying Power to PD.
I 09/06/08 22:11:16 00560 ports: port A11 PD Detected.
HP FW: K.14.51m
Module: ProCurve J8702A 24p Gig-T zl Module
AP FW: 9.4.0.0
ZD FW: 9.6.0.0
15 REPLIES 15
I have had good success with HP Procurve devices that are rated PoE+
For example the HP 3800 and 2920 and the ZF7982.
leonard_tsang
No issues with our HP 5406zl or 2920 switches..
point_of_presen
Seeing the same thing on an HP 2530-24G PoE+ switch. In addition we get the PoE light blinking orange, which is supposed to indicate a warning condition (but not a fault condition.) Switch thinks it's delivering power even though the light is on, but AP is not powering up.
HP-2530-24G-PoEP(config)# show power-over-ethernet 18
Status and Counters - Port Power Status for port 18
Power Enable : Yes
LLDP Detect : enabled
Priority : low Configured Type :
AllocateBy : usage Value : 17 W
Power Class : 4 Detection Status : Delivering
Over Current Cnt : 680 MPS Absent Cnt : 1
Power Denied Cnt : 0 Short Cnt : 0
Voltage : 0.0 V Current : 0 mA
Power : 14.8 W
HP-2530-24G-PoEP(config)# log -r
Keys: W=Warning I=Information
M=Major D=Debug E=Error
---- Reverse event Log listing: Events Since Boot ----
W 01/01/90 05:47:41 00562 ports: port 18 PD Over Current indication.
W 01/01/90 05:47:39 00562 ports: port 18 PD Over Current indication.
W 01/01/90 05:47:37 00562 ports: port 18 PD Over Current indication.
I 01/01/90 05:47:36 00561 ports: port 18 Applying Power to PD.
I 01/01/90 05:47:36 00560 ports: port 18 PD Detected.
point_of_presen
Never mind, firmware upgrade on the 2530 resolved the issue, despite no mention of PoE in the release notes. If anyone is having this issue, probably worth making sure you're up to date.
EDIT: Now on firmware YA.15.12.010
I had a similar issue with an HP switch (2910-24G-PoE+ al) and 7982's. I would get the orange blinking PoE light on an HP switch, tested with W_15_08_0012 and W_15_12_0011. With the firmware downgraded to W_14_38, the AP's powered up, but I didn't want to revert the firmware. Also, tested on a CIsco PoE switch, the AP's would not power.
I RMA'ed one of the 7982's and it worked on both the Cisco and updated HP. The rest of the AP's (being used with Ruckus PoE injectors) are currently being RMA'ed. The existing "broken" AP's had serial numbers starting with 3213 and 3313, while the new AP started with a 36. This lends credence to another forum posting about a change in hardware for the later revisions of the 7982's. If you are having a similar issue, please try RMA'ing at least one AP to test, even though you may not think it will fix the issue.
