Showing results forย
Search instead forย
Did you mean:ย
7982 No Web UI or Access after Reboot
I have a 7982 that I just pushed a firmware update to. Sorry for not paying attention to the firmware number, it was done via the FTP option. The firmware update completed, and I was able to get back into the UI after it was done without a problem. I wasn't sure if I also needed to Reboot the AP after the upgrade, so I used the UI to reboot it.
Now, I can't get back in the UI. The AP Is working fine - broadcasting the proper SSID, all clients connecting to it, etc. I just can't get back into the UI nor ping the device. I've tried power cycling it and soft resetting it with the button near the Ethernet connector, but no luck.
Any ideas what could have happened or what my fix will be?
3 REPLIES 3
