7782 vs 7762
lonnie_3404113
Contributor
I am looking at the 7762 and 7782 units for an outdoor deployment of a single unit at our farm market. I want the range and weather resistance and capacity to mesh on 5 GHz to a couple 7363's, but don't need the high-density client features of the 7782.
Are there any other major differences between these two units besides the high density client handling of the 7782?
8 REPLIES 8
Esteemed Contributor II
Only APs with like radios can mesh together.
Single-band (2.4G) only APs mesh on 2.4G, shared with clients. Dual-band APs mesh on 5G, and accept 5G clients, leaving 2.4G all for clients.
But... like radios also means b/g versus b/g/n.
Old 2925/2942/2741 are single-band 802.11b/g only, and can mesh together on 2.4G.
Newer 7942/7343 were single-band 802.11b/g/n, and can mesh together on 2.4G.
Dual-band APs with n on both bands, include 7962/7762/7363/7982/7782, and these APs can mesh together on 5G backhaul for both band clients.
What makes 7782 greater than 7762 is radio antennas and streams.
ZF7982 is 3x3:3, and ZF7962 is 3x3:2 spatial streams.
You have 7363 model APs with 2x2:2 antennas and spatial streams.
ZF7762 will be the correct choice as ZF7982 will offer no better performance.
lonnie_3404113
Contributor
Thanks!
mike_kuly
Please check out the new Ruckus outdoor 802.11ac AP , the R300. It just might be what you are looking for.
The T300 outdoor 802.11ac model AP, will be supported by ZoneFlex 9.9 release firmware. R300 (indoor 802.11n) model AP is supported from ZoneFlex 9.7, and
the R700 (indoor 802.11ac) model AP is supported in ZoneFlex 9.8 (current GA),
and later.
