04-21-2022 08:09 PM
I just updated my 7055 devices to firmware 104.0.0.0.1347. The are running as stand-alone APs
The Ethernet Port config pages show incorrect information and don't appear to save config changes.
The status pages shows:
Port Interface 802.1X Logical Link Physical Link Label 0 eth1 None Down Down LAN1 1 eth2 None Down Down LAN2 2 eth3 None Down Down LAN3 3 eth4 None Down Down LAN4 4 eth0 None Up Up 100Mbps full POE IN, LAN5/UPLINK
However the GUI shows that:
Port 1 is enabled and an access port
Ports 2,3,4 are disabled and are access ports
Port 5 is disabled and is a trunk port
A cable is plugged into Port 5 as the up-link to POE switch; none of the other ports are connected to devices.
The APs appear to still be working correctly for WiFi.
Is there something I'm not understanding about the port config, or is this some sort of bug?
I may try to downgrade to 100.1.0.0.432 and see if this helps.
Any other suggestions on how to resolve this?
