wireless telemetry devices monitoring system looses the connection
chris_turner_61
I have some telemetry devices that connect wireless to a central server and display the data. It has been reported that it has started to drop the display and looses the telemetry device. I have found the below in the log for thew AP unit and wondered if any one could point me in the right direction for investigation
04:44:05 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=e0:f5:c6:78:44:0d,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=20,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(5293,644244,6197,6105909)
Nov 11 04:53:04 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:b3,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=28,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(18314,20644420,25302,1040406)
Nov 11 04:53:15 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:b3,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=29,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(27,22244,21,1153)
Nov 11 04:53:29 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:b3,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=29,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(38,33832,31,1605)
Nov 11 04:54:50 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:b3,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=27,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(168,179104,159,6645)
Nov 11 04:55:04 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:b3,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=29,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(36,31272,30,1577)
Nov 11 04:55:15 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:b3,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=30,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(30,26084,24,1285)
Nov 11 04:55:39 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:b3,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=29,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(57,53168,50,2297)
Nov 11 04:57:17 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:d7,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=6,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(1028,705448,1037,43207)
Nov 11 05:42:01 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:06:1b:b0,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=7,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(10475,6967052,12562,516680)
Nov 11 05:48:58 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:06:1b:b0,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=9,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(270,171618,319,13360)
Nov 11 06:32:02 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:06:1b:b0,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=10,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(6183,4074440,7534,310725)
Nov 11 06:37:34 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:b3,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=31,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(11660,13130612,16107,661342)
Nov 11 06:37:49 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:b3,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=31,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(39,35112,35,1729)
Nov 11 06:38:19 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:d7,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=7,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(1425,869788,1605,67487)
Nov 11 07:01:52 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:06:1b:b0,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=6,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(5262,3512966,6436,263652)
Nov 11 07:04:55 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:d7,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=9,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(595,418144,738,30906)
Nov 11 07:08:00 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:d7,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=9,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(651,442908,801,33411)
Nov 11 07:14:15 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:d7,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=9,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(1222,830954,1533,62268)
Nov 11 07:14:32 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:d7,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=8,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(4,292,5,519)
Nov 11 07:40:41 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:d7,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=8,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(3,233,5,783)
Nov 11 07:41:26 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:d7,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=6,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(5,320,5,503)
Nov 11 07:42:38 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:d7,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=11,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(6,360,4,465)
Nov 11 07:42:53 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:d7,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=5,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(5,332,6,559)
Nov 11 07:59:59 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=0c:30:21:91:bc:de,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=5,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(4,190,2,96)
Nov 11 08:17:25 WH-AP-105 local2.alert syslog: IOCTL(89f8) failed for station deletion -- No such file or directory(2).
Nov 11 08:19:06 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:d7,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=8,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(772,806164,1327,56080)
Nov 11 08:19:18 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:d7,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=10,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(16,2216,26,1409)
Nov 11 08:19:26 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:d7,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=9,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(6,360,7,659)
Nov 11 08:20:17 WH-AP-105 daemon.warn Eved: MLME-REPLAYFAILURE.indication(wlan5 AES-CCM keyid=37 unicast RA:addr=c4:01:7c:45:9d:89 TA:addr=00:30:e6:05:b6:45) (pkt-rsc:0 k->rsc[0]:0
Nov 11 08:54:33 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=0c:30:21:91:bc:de,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=14,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(89,7945,53,2972)
Nov 11 09:02:29 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:b3,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=30,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(16556,18659979,23629,970860)
Nov 11 09:02:43 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:b3,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=31,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(38,33832,31,1605)
Nov 11 09:03:30 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:b3,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=32,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(98,100688,92,3997)
Nov 11 09:04:10 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:b3,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=32,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(89,90408,82,3629)
Nov 11 09:04:11 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:05:b6:45,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=35,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(7206,5783802,9010,375921)
Nov 11 09:04:12 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:d7,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=8,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(491,322750,490,20651)
Nov 11 09:04:15 WH-AP-105 kern.warn kernel: ath_dump_rxactivity: jiffies=490712283 last=490712229 lastpanic=0 rxpanic=0 thr=10000 inactive=54
Nov 11 09:04:15 WH-AP-105 kern.warn kernel: wifi0: ath_watchdog: hardware error; resetting
Nov 11 09:04:20 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:04:b6:d7,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=7,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(5,320,6,481)
Nov 11 09:23:41 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:06:1b:b0,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=13,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(4635,3015008,5560,228082)
Nov 11 09:54:42 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=0c:30:21:91:bc:de,func=ieee80211_input,line=1675,hint=received IEEE80211_FC0_SUBTYPE_DISASSOC,rx_rssi=13,ack_rssi=0,reason=0,freq=2437,chan=6,stats=(283,20700,91,6519)
Nov 11 09:58:06 WH-AP-105 daemon.warn Eved: STA-DISASSOC-REASON,nimac=00:30:e6:06:1b:b0,func=ieee80211_input,line=1675,hint=received
7 REPLIES 7
primoz_marinsek
Valued Contributor
You have ChannelFly ON or OFF?
chris_turner_61
Channelfly is off but background monitoring is running for both 2.4 and 5 ghz
primoz_marinsek
Valued Contributor
The telemetry device has a built in WLAN or are you using something to connect it to?
Does ti have an ETH port?
Which APs are you using?
they have built in wireless cards the AP are 7363
