MM2211 Metro Broadband Gateway has login problems
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-10-2013 01:21 AM
From Henk Kolk the Netherlands (henk.k@me.com)
It concerns a 2211 Metro Broadband Gateway. It is configured as a repeater and locked in frequency to an AP at ch 1. The unit does not work correctly. But It does not respond to the default IP address (192.168.30.1 or 192.168.1.1) The login screen doesnot appear . A reset to the factory settings does not help. A second unit gave the same result. Is there a default IP address I can use to connect and change the configuration?
9 REPLIES 9
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-12-2013 03:19 PM
There should be a username/password as well as the default IP address printed on the bottom of the unit. Is that what you're trying?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-20-2015 04:23 AM
i for got user name and password and there is no ip printed on it
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-14-2013 10:29 AM
Keith, many thanks for your reply. In the meantime I have studied some Ruckus publications and found the solution.
In the repeater mode there is no DHCP server. This is obvious because there are no clients. The MM2211 should be addressed wiith a fixed IP address in the same subset. E.g. 192.168.30.10 if the default IP address of the unit is 192.168.30.1.
This solved my problem. I could address the unit again.
Greetins,
Henk
Greetins,
Henk
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-14-2013 10:36 AM
@Henk - glad to hear it and thanks so much for sharing the solution for others!
