I am not able to access ZD web interface after changing VLAN Setup
kuldeep_malhotr
Hello everyone,,
AP failure to join the ZD and ... separate VLANs within a campus, ensure network access is permitted and working ShowBox between the network. ... Please also ping the ZD IP seen from this command's output. 4. ... US country Mobdro code is locked at the factory and it can not be changed VidMate in the field.... so i m unable to access it,.. plzzzz help...
0 REPLIES 0
