I have two R770's unleashed...
They are far from entry level ap's, but there is an odd setting when enabling wifi 6/7...
If you hover over it... it ends with the following:
Wi-Fi 6/7 clients connecting to this WLAN on a Wi-Fi 6/7 AP will not be able to use Wi-Fi 6/7 features such as OFDMA, TWT, 6 GHz operation, Preamble puncturing, 320MHz bandwidth.
So what is weird about this...
Is that the message is missing the MLO feature as well, but if you disable this to 'not allow' bad drivers to connect from wifi 5 devices, you cannot connect to wifi 6 or 7...
If you enable it, you lose the capabilities and one of the more important capabilities for wifi 7.
Is there any intention of having MLO work in wifi 7 in unleashed?
