R310 unleashed network, devices drop connection and just spinning wheel until router rebooted
gene_baker_7480
I have a residential location with 5 Unleashed R310 AP's on a Verizon connection using the Verizon Actiontec router/modem. Frequently connected devices drop connection, they look to be connected but device (eg. iPhone) shows spinning wheel under connection. The only way to reconnect the device is reboot the Actiontec modem/router, then it will last for awhile before repeating the problem.
2 REPLIES 2
1said_sanoussi
Sounds like a DHCP issue. Try to set a static IP on your client device and see if stays connected. If yes then your DHCP is not ok. You can if you want set a DHCP scope for your clients on your unleashed cluster. To see if that helps.
1said_sanoussi
Type a product name
