Problems accessing to the vSCG Web interface
hugo_a_sanchez
I have been experiencing diffculties installing and configuring vSCG and finally I got it worked but now I can't access to the web interface so I can login and makes changes.
The installation went just fine. I attached some screenshots so you can see what I"m talking about.
Thanks, Image_ images_messages_5f91c3d8135b77e2478ab1db_6efca0b84f24d35dee76b68f33677b74_vSCGcomplete_inline-f01eb34e-e159-4185-a49d-b02b9f35899a-93812158.png1407507418 Image_ images_messages_5f91c3d8135b77e2478ab1db_2c88801ed61b3d542347c64acdc109bd_vSCGerror_inline-9313b2d7-bbb4-4982-9957-03457c5e907b-802698667.png1407507430
2 REPLIES 2
herb_bautista
Internal Employee
Hello Hugo,
I presumed this was the same issue you and I worked on? If it is, then the resolution is to ensure the 3 interfaces are all in different subnet.
Herb
hugo_a_sanchez
yes! Thank you
