Control4 Halo Issues with Firmware Build 200.17.7.0.152 released 24 Feb 2025
RUCSAK1
I am not able to get the Halo Touch remotes to connect to the Ruckus Wifi (1x850 2x650) after upgrading this firmware, despite the firmware specifically saying it to improve control4 connections.  The remotes are connected with the 5GHz band, and don't have an option to roam to 2.4ghz.     The remotes work flawless with 200.16.x.x
A restore back to 200.16.x.x restores functions of the Halo remotes (after they are rebooted), and they connect and sync their projects without issue.
Any tips or advice?
200.17 GA Refresh
Resolved Issues
  • When static channel 85 on 6 GHz radio is configured, the AP works on Channel 1. [ER-14378]
  • Improve compatibility with Control4 Halo in 200.17. [UN-11081]
1 REPLY 1
Rohit_W
RUCKUS Team Member
The fix will be available in version 200.18.x.
