ZD web auth with radius session timeout problem
shan_hsun_lu
Customers want to re- auth within 6 days, we set the session timeout 518400 sec in the radius, set the grace period 8640 min, inactivity 500 min, but the customer still need to re-auth within 6 days, who has the relevant experience Can share? thank you!
In addition, I found in the log analysis tool a strange thing, the actual time only after less than 2 hours but the session timer does reduce the ten hours, some people know why?
Hostname = x550v Dvcinfo = Windows (Mobile) 8/8.1/10
DHCP assigned IP = 192.168.11.105 DHCP lease time = 552278 DHCP xID= 75733de3
Flags = Auth Assoc Authorized Local Installed Added to AP Roaming client Counted WMM MappingV4_added
VLAN = 1
Venue =
facebook token =
role-id = 1, vlan_id = 0, is_deny = 0, uplink_rate = 0, downlink_rate = 0
device policy: vlan_id = 0, is_deny = 3, uplink_rate = 0, downlink_rate = 0
stats -- last update Thu May 18 10:14:17 2017
rx_pkts132645tx_pkts358060rx_bytes7580008tx_bytes398875731last_rx_pkts83622last_tx_pkts235356last_rx_bytes14599036last_tx_bytes321941401retries0rssi36tx_power9403tx_rate72222dbm-69noise-105
session-id: 593F2814-0000007B
multi-session-id: ec8ca2b26978240a6488ecbb591c287263c6
MQ_statsQuedovrflwenqdeqreenqdeactXRetriesXTlimitsvoice(3):001745217574122000video(2):001547156114000data(1):013321473360733927000bkgnd(0):006910698474000
Privacy disabled, using clear text
Outstanding timers:
AP timer - expires in 247477 sec 623317 usec, next state = STA Null Func
Accounting timer - next accounting intrim updates in 38 sec 503397 usec
Session timer - Session terminates in 128 hour(s) 30 min(s) 14 seconds
DHCP assigned IP = 192.168.11.105 DHCP lease time = 601168 DHCP xID= 1ff318b
Flags = Auth Assoc Authorized Added to AP Counted WMM MappingV4_added
VLAN = 1
Venue =
facebook token =
stats -- last update Thu May 18 11:39:52 2017
rx_pkts6649tx_pkts29306rx_bytes395950tx_bytes14212762last_rx_pkts0last_tx_pkts0last_rx_bytes0last_tx_bytes0retries0rssi38tx_power9917tx_rate72222dbm-67noise-105
session-id: 593F2814-0000007D
multi-session-id: ec8ca2b29fe8240a6488ecbb591d09806812
MQ_statsQuedovrflwenqdeqreenqdeactXRetriesXTlimitsvoice(3):0893649676320000video(2):002882913000data(1):061697517638669000bkgnd(0):0526772846174000
Outstanding timers:
AP timer - expires in 296367 sec 211091 usec, next state = STA Null Func
Accounting timer - next accounting intrim updates in 567 sec 269398 usec
Session timer - Session terminates in 110 hour(s) 16 min(s) 4 seconds
1 REPLY 1
Esteemed Contributor II
