Announcement: SmartCell Insight (SCI) v5.2.1 GA Release is available on Support
Esteemed Contributor II
Ruckus Networks hard working SCI developers and QA have released a new version 5.2.1 GA,
with a new Authentication tab and enhanced Data Explorer dimensions and measures.  Find the
Documentation and Firmware on our Support portal at these links.
SmartCell Insight (SCI) Version 5.2.1(GA) Installation Guide
https://support.ruckuswireless.com/documents/2646-smartcell-insight-sci-version-5-2-1-ga-installatio...
SmartCell Insight (SCI) Version5.2.1 (GA) API User Guide
https://support.ruckuswireless.com/documents/2647-smartcell-insight-sci-version-5-2-1-ga-api-user-gu...
SmartCell Insight (SCI) Version5.2.1 (GA) User Guide
https://support.ruckuswireless.com/documents/2648-smartcell-insight-sci-version-5-2-1-ga-user-guide
SmartCell Insight (SCI) Version5.2.1 (GA) Upgrade Guide
https://support.ruckuswireless.com/documents/2649-smartcell-insight-sci-version-5-2-1-ga-upgrade-gui...
SmartCell Insight (SCI) Version5.2.1 (GA) Release Notes
https://support.ruckuswireless.com/documents/2650-smartcell-insight-sci-version-5-2-1-ga-release-not...
SCI 5.2.1 (GA) Software Release(Local Update Image):
https://support.ruckuswireless.com/software/1990-sci-5-2-1-ga-software-release-local-update-image
SCI 5.2.1 (GA) Software Release(.ova Image):
https://support.ruckuswireless.com/software/1989-sci-5-2-1-ga-software-release-ova-image
SCI 5.2.1 (GA) Software Release(.qcow.tgz Image):
https://support.ruckuswireless.com/software/1988-sci-5-2-1-ga-software-release-qcow-tgz-image
SCI 5.2.1 (GA) Software Release(.vhd.gz Image):
https://support.ruckuswireless.com/software/1987-sci-5-2-1-ga-software-release-vhd-gz-image
SCI 5.2.1 (GA) Software Release(GCE .tar.gz Image):
https://support.ruckuswireless.com/software/1986-sci-5-2-1-ga-software-release-gce-tar-gz-image
SCI 5.2.1 (GA) Software Release(Azure Image):
https://support.ruckuswireless.com/software/1985-sci-5-2-1-ga-software-release-azure-image
      Thanks and best regards,
0 REPLIES 0
