Difference between the role default and 802.11b/g,802.11b/g/n,802.11b/g/n/ac does these effect internet slowness ,if how to over come it.
Hi All,in my ruckus zd portal  i have seen role as default for some users for some users it is not showing any role and for some users it is showing 802.11b/g ,802.11b/g/n and 802.11b/g/n/ac does these specify anything interms of internet effective utilization.
Thanks in advance.
1 REPLY 1
you are confusing two different things.
b, g, n and ac refer to the speed at which your clients and access points talk to each other (using wifi) -those are the designation letters for 802.11x protocols.
Your internet speed is determined by your connection to your ISP.
A slow internet connection cannot be improved by a fast client to AP wifi connection.
Nothing is simple!
You also mention default and roles to further confuse.
