ZD1200 Recomendation for Upgrade, and Upgrade path.
departamento_si
Hi to all.
i ́m newbie with ruckus. I have some questions.
I ́m now on a ZD1200 installation with this version of software installed: 9.10.0.0.218
With r500, that are compatible with the last Firmware version.
Could you tell me if its recommended to go to last version? Usually on IT we say, don ́t touch if works...
Upgrade path:
Start on 9.10.0.0.218 (Version  25/06/2018)
go to  9.13.4.41 (9.13.3 Refresh)
go to  10.0.0.0.1424 (10.0 GA)
go to last version 10.2.1.0.75 (10.2.1 MR1 Version 15/02/19)
It ́s correct?
Any recomendation?
Regards.
2 REPLIES 2
shatarupa_rahut
I would recommend you to upgrade till F/W 10.1.2 build 210.
The upgrade path would be:
9.10.0.0.218 --> 9.13.3.0.164 --> 10.1.2.0.210
https://support.ruckuswireless.com/documents/2276-zonedirector-9-13-3-mr3-refresh7-release-notes
https://support.ruckuswireless.com/documents/2614-zonedirector-10-1-2-mr2-refresh1-release-notes
Thanks,
Shatarupa
krishan_parasha
Contributor
Yes you can go r500 is supported with 10.x
X
X
Labels
