In some situations, administrators may wish to disable the LED lights on the access points to avoid drawing attention to them, when installed in a public location, for example.
To disable status LEDs on all APs of a specific model:
- Go to Access Points > Summary > Edit > Other.
- Select the AP model from the list and enable the option Disable Status LEDs. The setting must be configured for each AP model individually.
- Click Finish to save your changes
For more info on the LED behavior meaning please visit: https://community.ruckuswireless.com/t5/RUCKUS-Self-Help/Ruckus-AP-LED-indicator-meaning/td-p/67848
