Issue: Unit 3 status is showing as reserve state under the show stack output below:
ICX7750-26Q Router# show stack
T=1d17h49m48.5: alone: standalone, 😧 dynamic cfg, S: static
ID Type Role Mac Address Pri State Comment
1 S ICX7750-26QXG active cc4e.2438.7280 128 local Ready
2 S ICX7750-26QXG member 748e.f8f9.6300 128 remote Ready
3 S ICX7750-26QXG member 0000.0000.0000 0 reserve
4 D ICX7750-48XGF member 609c.9f7f.9400 128 remote Ready
Reasons:
-If unit stuck in boot loop.
-If there is a physical layer issue such as stacking cable, stacking module.
-If unit is faulty or hardware issue.
Recovery Steps:
-Try software recovery by taking console access for this unit.
https://docs.commscope.com/bundle/fastiron-08095-upgradeguide/page/GUID-9B5D5A56-039D-44FB-8FD2-B9B55E71ADE8.html
-Try power cycling the switch after removing it from the stack.
-Check if it’s related to any known defect.
-Try factory resetting the switch.
-Try below steps by removing switch from the stack taking console access.
>>Enter switch boot mode
>>Give command: use default-configuration
>>Reload the switch.
-Try changing the stacking cables and stacking ports.
-Switch not powering on try checking the power cable and power source.
-Replace the switch with the same model if switch fails to power on.
