The power management on the ICX switches until version 9010 have Static Power Management only where we have inline power enabled on the interface by default.
Dynamic Power management helps with dynamic power allocation on the ports based on power consumed by the end device connected to the switch.
Supported Models
- ICX 7150
- ICX 7550
- ICX 7650
- ICX 8100
- ICX 8200
Supported version.
Using Static Power Management on the Switch:
Command:
Ruckus(config)#inline power
Output:
Ruckus(config)#show poe
Power Capacity: Total is 124000 mWatts. Current Free is 64000 mWatts.
Power Allocations: Requests Honored 8 times
1/1/1 On On 4733 30000 2P-IEEE Class 4 3 n/a
1/1/2 On Off 6015 30000 2P-IEEE Class 4 3 n/a
1/1/3 On Off 0 0 n/a n/a 3 n/a
1/1/4 On Off 0 0 n/a n/a 3 n/a
1/1/5 On Off 0 0 n/a n/a 3 n/a
1/1/6 On Off 0 0 n/a n/a 3 n/a
1/1/7 On Off 0 0 n/a n/a 3 n/a
1/1/8 On Off 0 0 n/a n/a 3 n/a
Total 10748 60000
Using Dynamic Power Management on the Switch:
Command and options:
Ruckus(config)#inline power allocation
dynamic Move from Static allocation to Consumption based Power allocation -
CAUTION: PDs can get shutdown, make sure overall consumption
doesn't exceed the budget
Ruckus(config)#inline power allocation dynamic
ASCII string all or unit-id list: 2,3,5-7,8 (no space)
Ruckus(config)#inline power allocation dynamic all
Output:
Power Capacity: Total/Reserved/Unconsumed is 124.0/0.0/113.2 Watts.
1/1/1 On On 4733 30000* 2P-IEEE Class 4 3 n/a
1/1/2 On Off 6015 30000* 2P-IEEE Class 4 3 n/a
Total 10748 60000
(*) Allocated power being dynamically managed.
Using Dynamic Power Management on the Switch with Priority:
The devices which are mission critical Priority can be assigned to those end devices using below command.
Ruckus(config)#int e 1/1/1
Ruckus(config-if-e1000-1/1/1)#inline power priority
DECIMAL Priority value 1..3 (highest..lowest)
<cr>
Ruckus(config-if-e1000-1/1/1)#inline power priority 1
Output:
1/1/1 On On 4733 30000* 2P-IEEE Class 4 1 n/a
Total 10748 60000
Link referred:
