Issue: To Install valid purchased license for 8x10g speed on the interfaces or ports, as running Trial license for 45 days on the units.
- Enter the show license installed command to verify the licenses already running or installed on the device.
Test-switch# show license installed
Unit License Name L3 Prem PoD Speed Ports MACsec SerialNo(L3/ICX7250) SerialNo(PoD/MACsec)
1 l3-base-2X10G No Yes 10G 2 NA
2 l3-base-2X10G No Yes 10G 2 NA
- Enter the show version command to verify license details. The Current License field displays the license package you have currently installed on the device.
Test-switch# show version
UNIT 1: compiled on May 14 2023 at 10:06:30 labeled as SPS08095j
(31457280 bytes) from Primary SPS08095j.bin (UFI)
SW: Version 08.0.95jT211
Compressed Primary Boot Code size = 786944, Version:10.1.26T215 (spz10126)
Compiled on Tue Dec 29 12:43:15 2022
UNIT 2: compiled on May 14 2023 at 10:06:30 labeled as SPS08095j
HW: Stackable ICX7250-48-HPOE
UNIT 1: SL 1: ICX7250-48P POE 48-port Management Module
Serial #:XXX111XXXXY
Software Package: BASE_SOFT_PACKAGE (LID: abcdefghijk)
Current License: l3-base-2X10G
P-ASIC 0: type B344, rev 01 Chip BCM56344_A0
UNIT 2: SL 1: ICX7250-48P POE 48-port Management Module
Serial #:YYY111YYYXY
Software Package: BASE_SOFT_PACKAGE (LID: lmnopqrstuv)
- Enter the license install perpetual command, followed by the unit number and the purchased license name.
# license install perpetual 1 8x10g
# license install perpetual 2 8x10g
- Enter the license set serial command for POD followed by serial number received with the Certificate of Entitlement (CoE) after license activation.
#license set serial 1 pod <TEST123>
#license set serial 2 pod <TEST456>
- Confirm the license installation with the show license installed command.
Test-switch#show license installed
1 l3-base-8X10G No Yes 10G 8 NA TEST123
2 l3-base-8X10G No Yes 10G 8 NA TEST456
