Equipment:
RUCKUS ICX 7150-C08P switch box (x1); RUCKUS R320 series AP (x3) each individually connected to their own port on the switch box via Cat 6 LAN cables
Inciting event:
In an effort to reorganize/reposition the switch box in the multi-media cabinet (to make room for new equipment) the switch box was temporarily disconnected and within 3-5 minutes, reconnected to the power source. The LAN cables were also disconnected and reconnected (possibly to new port positions for better wire management).
Problem:
The Wifi signal stopped broadcasting from all APs. The master AP (and one other AP) has a solid green "power" light and a blinking green "CTL" light. 1 of the 3 APs has a blinking green "power" light and a solid greed "CTL" light. NOTE: prior to the inciting event, the network was working perfectly and in a MESH configuration.
***Also to note, the LAN indicator lights on the ports on the switch box are yellow for the 3 ports connected to the 3 APs and green for my other devices connected to the other ports (good internet signal on the other ports ex. my MoCA devices are working fine)***
Attempts to troubleshoot:
1) Power cycled the APs and the switch box several times.
2) Confirmed good internet signal coming from the router (AT&T)
3) Following forum advice (and a RUCKUS instructional youtube video) I reset the master AP (pressed the reset button for 10 seconds).
Where I am now:
Currently I have 2 wifi signals (Configure.me- XXXX presumably coming from the master AP that I resent) and (Recover.me-XXXX presumably from one of the other 2 APs that were in MESH mode and is password protected).
When I try to reconfigure the network again (using Configure.me- XXXX) using at least 3 different ISPs and using 192.168.0.1 or unleashed.ruckuswireless.com the most I get is a loading pages saying something close to "Preparing your ruckus network. This may take a few minutes" (wording may be off but something like this). Unfortunately it is stuck in this page and does not proceed to the setup wizard screen despite waiting many minutes and resetting the AP a few times.
Any input/help would be appreciated. I would be OK to resent the whole thing to factory setting and start over if needed.
Thanks in advance
