Had a power outage and access points used to have the 2.4g and 5 lights on.. now the power lights are blinking along with the CTL lights and I don't know what to do. Also I an unable to log into the app.
Hi @Greenezr1
Hope you are doing well!!!
Thank you for the information you shared,
From the case description, I could understand that your RUCKUS Internet setup is not working after a power outage.
This issue may happen when the Switch starts running on the Routing code. The Switch should run on the Switching code to avoid these issues for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
You can take Console access to the switch in order to verify, if the switch is able to connect properly to Access Points or if it has a ‘Routing Code’ issue which happens due to power outages/ power spikes most of the time, this is a known issue for Lennar home users.
-MAC address: Physical address of the device this never changes
- An IP address is a unique address (logical) that identifies a device on the internet or a local network like your home (this can change and may not be the same as the one shown on the dashboard)
There are multiple ways to fix this issue as described in below steps:
Please follow the below steps:
1. To fix this issue, we must identify the ‘current’ IP address assigned by your local router to the switch ICX-7150-C12P
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-find-my-Ruckus-Devices-IP-address-using-free-applications/td-p/47027
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-remotely-access-to-ICX-7150-12P-or-access-points-quot/td-p/47388
ICX7150-C12 Router>
3. Here is a quick guide for understanding how to fix the 'routing code issue' however, you only need to run the following commands once you are on the command line 'CLI'
show version
copy flash flash secondary
(Please share the output screenshot of the ‘show version’ command to check your current Switch version, if the upgrade is required to avoid this problem in the future)
Example:
ICX7150-24P Router>enable (hit enter to accept the command) ICX7150-24P Router#copy flash flash secondary (hit enter to accept the command and wait: until the flash finished) ICX7150-24P Router#boot system flash secondary yes (hit enter to accept the command: the switch will reboot)
There are Two ways:
I) How to Fix Routing code issues on Lennar Home users via CLI
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issues-on-Lennar-Home-users/td-p/47305
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-solve-the-routing-code-issue-in-your-ICX7150-Switch/td-p/47335
II) Or WEB access option
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issues-on-Lennar-Home-users-via-Web-GUI/m-p/47959#M1998
4. If access via IP address is not possible here is a guide on how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case we need a USB type C to USB standard or Console cable Rj45 to USB.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-console-in-the-ICX-7150-12c-using-a-Windows-Machine/td-p/46759
Once you are logged in to the ICX-7150-C12P please follow and perform the same commands that are on point '3'
Lennar Home Community.
