After power outage I have intermittent internet access. I understand I need a replacement as the Ruckus is rebooting as a router and not an access/switch?
How do I get a replacement as my neighbors have done?
John
Hi @jcgraybeal
Hope you are doing well
If there was a blackout or power outage and the switch reboot because of that, most possible your switch starts running the wrong code which we call ‘routing code’ this is a known issue.
MAC address: Physical address of the device this never changes
An IP address is a unique address (logical) that identifies a device on the internet or a local network like your home (this can change and may not be the same as the one shown on the dashboard)
1- To fix this issue, we must identify the ‘currently’ IP address assigned by your local router to the switch
-We can try the IP address that shows in the dashboard copy and paste it in the URL if that redirects you to the login page for the ICX-7150-C12P that is the correct one if not.
I will leave you a guide how to perform an IP scanner on your local network to identify the switch IP address very easily.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-find-my-Ruckus-Devices-IP-address-using-free-applications/td-p/47027
2-Once we identified the IP address of the switch proceed to access remote to the device 'command Line'
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-remotely-access-to-ICX-7150-12P-or-access-points-quot/td-p/47388
If you can access to the Command line should look like this:
ICX7150-C12 Router>
3-Here is a quick guide to understand how to fix the 'routing code issue' but basically you need only need to run the following commands once you are on the command line 'CLI'
copy flash flash secondary
example:
ICX7150-24P Router>enable (hit enter to accept the command) ICX7150-24P Router#copy flash flash secondary (hit enter to accept the command and wait: until the flash finished ) ICX7150-24P Router#boot system flash secondary yes ( hit enter to accept the command : the switch will reboot )
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issues-on-Lennar-Home-users/td-p/47305
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-solve-the-routing-code-issue-in-your-ICX7150-Switch/td-p/47335
Or WEB access option
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issues-on-Lennar-Home-users-via-Web-GUI/m-p/47959#M1998
4-If the access via IP address is not possible here is a guide how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case we need a USB type C to USB standard or Console cable Rj45 to USB.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-console-in-the-ICX-7150-12c-using-a-Windows-Machine/td-p/46759
Once you are log in the ICX-7150-C12P please follow up the same steps that are on point '3'
Note:We do not replace Switches due to this know issue without having done the necessary troubleshooting
Best Regards
Fernando Vasquez
I can access to the command line via mac terminal. However, none of the commands are available after “enable"
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issues-on-Lennar-Home-users/m-p/47305
The AP is in "ICX7150-C12 Router” mode.
How do I fix this. (I have tried via usb with a mac and windows and I cannot connect) So using my Mac via Terminal is the way to get access. I just need to know what commands to use?
"Show version” The command is either unrecognized or incomplete. To view a list of commands that you can run from this context, type '?' or 'help'.
"Show flash” The command is either unrecognized or incomplete. To view a list of commands that you can run from this context, type '?' or 'help'.
Below are the commands available:
exit Ends the CLI session.help Shows available commands.quit Ends the CLI session.history Shows a list of previously run commands.disable Disables privileged commands.ping <IP-ADDR/DOMAIN-NAME>Sends ICMP echo packets to an IP/IPv6 address or domain name.ping <IP-ADDR/DOMAIN-NAME> -s <NUMBER>Sends ICMP echo packets to an IP/IPv6 address or domain name with -s optionto set the size of packet.reboot Reboots the controller.shutdown Shut down ZoneDirector, to power on ZoneDirector again, press the powerbutton. When the Status LED is lit steadily, you can then reconnect toCLI.set-factory Set factory default.switch-ap switch the controller to APdata-privacy Excutes data-privacy command.data-privacy delete <MAC> <FTP Url>Delete PII Data by device MAC.data-privacy search <MAC> <FTP Url>Search PII Data by device MAC.config Configures options and settings.logo nodog Remove all dogs from logo.logo default Back to default logo.easyDpl-get-status Get easy-deployment running status.easyDpl-disable Debug command, please stop easy-deployment by Webpage. This command stopseasy-deployment and disables tr069 function, may cause mechanism chaos wheneasy-deployment is after prepareimage status.debug Manages system debug options.show location-services allDisplays configured location services for all venues.show location-services name <WORD>Displays information for the specified venue.show aaa all Displays a list of available AAA servers.show aaa name <WORD>Displays information for the specified AAA server.show dhcp all Displays a list of available DHCP servers.show dhcp name <WORD>Displays information for the specified DHCP server.show ap all Displays a list of all approved devices.show ap devname <WORD>Displays information for the specified device.show ap mac <MAC> Displays information for a device that matches the specified MAC address.show ap-group all Displays all AP groups.show ap-group name <WORD>Displays information for the specified AP group.show ap-policy Displays the ap policy settings.show config Displays current system options.show performance ap-radio2-4 mac <MAC>Displays information for a device that matches the specified MAC address.show performance ap-radio5 mac <MAC>Displays information for a device that matches the specified MAC address.show performance station mac <MAC>Displays information for a device that matches the specified MAC address.show sysinfo Displays current system status.show ethinfo Displays current system ethernet status.show techsupport Displays current system options and status.show mgmt-acl all Displays a list of all management access control.show mgmt-acl name <NAME>Displays information for the specified management.show static-route allDisplays a list of all static route.show static-route name <NAME>Displays information for the specified static router.show wlan all Displays a list of all WLAN services (Names).show wlan name <NAME>Displays information for the specified WLAN service (NAME).show wlan name <NAME> stationsDisplays a list of wireless stations associated with a WLAN service.show l2acl all Displays a list of L2 ACL.show l2acl name <WORD>Displays information for the specified L2 ACL.show allowlist all Displays a list of allowlist.show allowlist name <WORD>Displays information for the specified allowlist.show l3acl all Displays a list of L3/L4/IP ACL.show l3acl name <WORD>Displays information for the specified L3/L4/IP ACL.show hotspot all Displays a list of hotspot.show hotspot name <WORD>Displays information for the specified hotspot.show guest-access-service allDisplay a list of guest access service.show guest-access-service name <WORD>Displays information for the specified guest service.show hs20op all Displays a list of hotspot 2.0 operator.show hs20op name <WORD>Displays information for the specified hotspot 2.0 operator.show hs20sp all Displays a list of hotspot 2.0 service provider.show hs20sp name <WORD>Displays information for the specified hotspot 2.0 service provider.show role all Displays a list of roles.show role name <WORD>Displays information for the specified role.show vlan-pool all Displays a list of vlan pools.show vlan-pool name <WORD>Displays information for the specified vlan pool.show user all Displays a list of users.show user name <WORD>Displays information for the specified user.show current-active-clients allDisplays a list of current active clients.show current-active-clients mac <MAC>Displays information for the specified current active clients.show mesh info Displays mesh Information.show mesh topology Displays mesh topology.show dynamic-psks Displays generated dynamic PSK.show guest-passes Displays generated guest passes.show guest-access-generationDisplay generation information for guest access.show portal-auth-generationDisplay generation information for guest access.show rogue-devices Displays all rogue devices.show events-activitiesDisplays last 300 events/activities information.show alarm Displays last 300 alarm information.show license Displays license.show usb-software Displays USB Software Package information.show app-policy Displays the application policy settings.show user-app-ip Displays the user defined application based on IP.show user-app-port Displays the user defined application based on Port.show wificalling Displays the WIFI Calling profiles.show url-filtering Displays Url Filtering profiles.show session-timeoutDisplays CLI session timeout interval.show active-wired-client allDisplays a list of active wired clients.show active-wired-client mac <MAC>Display information for the active wired clients that match the specified MACaddress.show radius-statistics server-allDisplays a RADIUS statistics list of all RADIUS servers (default: recordedfrom power on).show radius-statistics server-all latest-ten-minRADIUS statistics recorded for latest 10 minutes.show radius-statistics server-all latest-one-hourRADIUS statistics recorded for latest 1 hour.show radius-statistics server-all latest-one-dayRADIUS statistics recorded for latest 1 day.show radius-statistics server-name <WORD>Displays RADIUS statistics based on a specified RADIUS server (default:recorded from power on).show radius-statistics server-name <WORD> latest-ten-minRADIUS statistics recorded for latest 10 minutes.show radius-statistics server-name <WORD> latest-one-hourRADIUS statistics recorded for latest 1 hour.show radius-statistics server-name <WORD> latest-one-dayRADIUS statistics recorded for latest 1 day.show radius-statistics wlan-allDisplays a RADIUS statistics list of all WLANs (default: recorded for latest1 day).show radius-statistics wlan-all latest-ten-minRADIUS statistics recorded for latest 10 minutes.show radius-statistics wlan-all latest-one-hourRADIUS statistics recorded for latest 1 hour.show radius-statistics wlan-name <NAME>Displays RADIUS statistics based on a specified WLAN (default: recorded forlatest 1 day).show radius-statistics wlan-name <NAME> latest-ten-minRADIUS statistics recorded for latest 10 minutes.show radius-statistics wlan-name <NAME> latest-one-hourRADIUS statistics recorded for latest 1 hour.show load-balance Displays AP load balancereset radius-statistics server-allReset RADIUS statistics of all servers to zero (default: recorded from poweron).reset radius-statistics server-all latest-ten-minRADIUS statistics recorded for latest 10 minutes.reset radius-statistics server-all latest-one-hourRADIUS statistics recorded for latest 1 hour.reset radius-statistics server-all latest-one-dayRADIUS statistics recorded for latest 1 day.reset radius-statistics server-name <WORD>Resets RADIUS statistics to zero based on a specified RADIUS server (default:recorded from power on).reset radius-statistics server-name <WORD> latest-ten-minRADIUS statistics recorded for latest 10 minutes.reset radius-statistics server-name <WORD> latest-one-hourRADIUS statistics recorded for latest 1 hour.reset radius-statistics server-name <WORD> latest-one-dayRADIUS statistics recorded for latest 1 day.reset radius-statistics server-name <WORD> masterResets RADIUS statistics of master server to zero (default: recorded frompower on).reset radius-statistics server-name <WORD> master latest-ten-minRADIUS statistics recorded for latest 10 minutes.reset radius-statistics server-name <WORD> master latest-one-hourRADIUS statistics recorded for latest 1 hour.reset radius-statistics server-name <WORD> master latest-one-dayRADIUS statistics recorded for latest 1 day.reset radius-statistics server-name <WORD> standbyResets RADIUS statistics of standby server to zero (default: recorded frompower on).reset radius-statistics server-name <WORD> standby latest-ten-minRADIUS statistics recorded for latest 10 minutes.reset radius-statistics server-name <WORD> standby latest-one-hourRADIUS statistics recorded for latest 1 hour.reset radius-statistics server-name <WORD> standby latest-one-dayRADIUS statistics recorded for latest 1 day.reset radius-statistics wlan-allReset RADIUS statistics of all WLANs to zero (default: recorded for latest 1day).reset radius-statistics wlan-all latest-ten-minRADIUS statistics recorded for latest 10 minutes.reset radius-statistics wlan-all latest-one-hourRADIUS statistics recorded for latest 1 hour.reset radius-statistics wlan-name <NAME>Resets RADIUS statistics to zero based on a specified WLAN (default: recordedfor latest 1 day).reset radius-statistics wlan-name <NAME> latest-ten-minRADIUS statistics recorded for latest 10 minutes.reset radius-statistics wlan-name <NAME> latest-one-hourRADIUS statistics recorded for latest 1 hour.session-timeout <NUMBER>Sets the CLI session timeout.ap-mode Go to local AP's CLI from Master's CLI.
From the web access, I do not have anything that looks like the above? I am logging in as “admin"
Based on your description you are connected to the Access point CLI instead of the Switch, however, we can identify the Switch as a neighbor, by running the next commands get lldp neighbors, as you see in my example the IP address of the Switch is 192.168.0.3
1:Running the LLDP command to find the neighbors from the connection you already have to the Access Point. One of your neighbors will be your switch,
In my example, the IP address of the switch is "192.168.0.3 ".
Ruckus>enable
Ruckus#ap-mode
ruckus(ap-mode)# get lldp neighbors
2: Once you know the IP address of the Switch, please try to gain access to the switch as you did with the Access Point CLI.
Yarenis Hernández.
Technical Support Engineer | L2 TAC Wired | Lennar Home Community
That makes sense, but this this what I get when I run "get lldp neighbors"
There is no IP address???
Please login: adminPassword:Welcome to Ruckus Unleashed Network Command Line Interfaceruckus> enableruckus# ap-modeYou have all rights in this mode.ruckus(ap-mode)# get lldp neighbors-------------------------------------------------------------------------------LLDP neighbors:-------------------------------------------------------------------------------Interface: eth0, via: LLDP, RID: 1, Time: 0 day, 05:01:55Chassis:ChassisID: mac dc:ae:eb:2c:b5:7eSysName: ICX7150-C12 RouterSysDescr: Not receivedCapability: Bridge, onCapability: Router, onPort:PortID: mac dc:ae:eb:2c:b5:80PortDescr: GigabitEthernet1/1/3-------------------------------------------------------------------------------OK
jcgraybeal
This can happen because the Switch is running a routing code, so will cause bad connectivity, and LLDP protocol will may not share all its data, try the next steps.
1:Remove the cable from the Switch and the ISP router and reconned.
2:Run back the command from the Access Point.
3:If still no show, you need to gain access to the Switch via console, because the IP address will not be found. Check the next guide to gain console access.
How to console in the ICX-7150-12CP 'Ruckus Switch'
https://www.youtube.com/watch?v=YXR4xhkw3q8
(Tutorial for MAC)
https://www.youtube.com/watch?v=1AcJokMm78U
4:Once you gain access, follow up the next guide:
Guide#1:
Guide#2:
Getting closer, I have a windows machine connected via the USB C. And MobaXterm. But the screen is just running at "user and log in” prompts. Like the enter key is stuck down? How do I stop the screen to actually sign in? Something is wrong. I can watch it boot looks OK but never gets to a point I can log in? The screen is just running with the log in prompts?
User Access Verification
Please Enter Login Name:
Please Enter Password:
User login Failure.
User Access VerificationPlease Enter Login Name:Please Enter Password:User login Failure.
I can not seem in log on with Putty
I tried SecureCRT and MobaXterm and both are just caught in the login loop over and over and over. I have reset to factory reset and same thing. Caught in the login loop.
Any other ideas?
Like you are from Console access, let's perform a password recovery.
1:Console access to the switch
2:Reset the device (power cycle the switch)
Commands:
3- Enter “b” to stop at boot monitor
Enter the next command no password
(skips the password check when the system comes back in the next boot)
4- Enter the next command reset
Set new password commands:
Enable
Config t
username super password sp-admin
Enable super-user-password sp-admin
write memory
Reload
https://www.youtube.com/watch?v=XJS28DWbHM4
I have the password. It is that the login is in a never ending loop. It does not stop and I there is not opportunity to enter a user name or password. It just keep looping without stopping. I have tried CTRL Z CTRL C nothing stops the looping .
Try the password recovery if still does not allow you, please send me a screenshot of the error, not just the logs please the screenshot.
how do I send you a screen shot? You really need a video. The screen just loops and loops never stopping, no way to stop the loop no way to enter anything.
I am able to log in via PuTT6 but all the same. no way to stop the looping. No way to use “b” to stop the looping. Can’t reset password. Just a continuous looping for log in info. Nothing will stop the looping. The running of the screen of the king in info. “B” does nothing to stop it.
1. I received the new switch.
2. Plugged in and working under the switch flash. However, the secondary flash is the router flash.
3. I was able to get the switch IP address via terminal and the "get lldp neighbors” command.
4. I can log into the switch via the IP address.
5. When I connect vie a usb C cable and Putty I get the same scrolling/looping screen see this link.
https://youtube.com/shorts/asGKeUwiSXU
This is the exact same thing that the old switch was doing. I am UNABLE to enter any commands. UNABLE to enter a username or a password. UNABLE to stop the scrolling/looping.
5. HOW CAN I CHANGE THE SECONDARY FLASH to the switch. Therefore, ensuring that when I loose power again the switch will stay in switch mode and not go to its secondary router flash?
Have you tried to access via WEB access option :
Use the following guide as reference:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-an-Upgrade-via-Web-GUI-ICX7150-Switch/td-p/48200
Have you tried Telnet option ?
The command is :
nc ipswitch 23
SSH can be multiples combinations
SSH username@IPswitch
ssh admin@192.168.0.54
ssh super@192.168.0.554
The passwords can be :
The same as the unleashed dashboard or Lennar / sp-admin / Ruckus1 / Ruckus!
Admin usernames and passwords for the Ruckus Wi-Fi Access Points/Switch for Lennar home users
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Admin-usernames-and-passwords-for-the-Ruckus-Wi-Fi-Access-Points/td-p/46740
All passwords and usernames are key sensitive
Hi
Can you provide instruction on how to use the Web Interface to copy the switch flash from the primary to the secondary boot? I have Primary boot is the switch flash and Secondary boot flash is the Router
The only way to have the switch image on both Primary and Secondary is via CLI
https://www.youtube.com/shorts/CbJ-gHkNZ7M
I have a new 7150. It is working correctly now and it is running as a switch. HOWEVER I can not intact with it via a CLI.
I need to copy the Primary Flash/Bios from the Primary to the Secondary via CLI.
However just as my last 7150 when I connect via a USB C from the 7150 to a USB on a (2 different Windows laptops) laptop computer I get the same issue as before the login and username are just looping/scrolling. There seems to be no way for the terminal program (either Putty or Mobaxterm) to allow me to enter any keyboard inputs. No way to “b” for a new password. No way for anything? Please see youtube video.
I have tried 2 different computes and now I have a new 7150?
Please tell me how I can assess a CLI?
Hi jcgraybeal
Greetings of the day!!!
Hope you are doing well.
Could you please update us on the status of the issue?
Lennar Home Community.
