https://support.ruckuswireless.com/cases/01409741
This is the the same issue as in
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Ruckus-switch-unreachable-disconnected-after-power-outage/m-p/12625
But I do not see a solution for that. I am not a network specialist so some suggestions are too technical for me
Hi @EduardoC
Ok, so if the Online web access is not working, you need to get access via console, using the next connection the USB will be connected on your computer and the type C on your ICX7150 Switch.
Note: the SSH and Telnet access will not work for you, because you are having connectivity issues to reach the IP address 192.168.1.170 and those are for remote access, however console is local, so will no matter if you have or not an IP address.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-solve-the-routing-code-issue-in-your-ICX7150-Switch/td-p/47335
RUCKUS ICX 7150 USB TYPE C CONSOLE (tutorial video for ICX)
https://www.youtube.com/watch?v=YXR4xhkw3q8
(Tutorial for MAC)
https://www.youtube.com/watch?v=1AcJokMm78U
Yarenis Hernández
Are you an Unleashed Lennar Home client?
Yes we are
Just to clarified your issue, please response the next questions:
Is your Switch online, but from Unleashes is displayed as disconnected?
Is your unleashed network working fine?
Are all your Access Point online and working as expected?
Are you having connectivity issues in your Unleashed network?
Can you gain accesses to the Switch IP address that may be displayed in the Unleashed dashboard, if that is the case, access and provide the next information from there?
While your computer or phone is connected to the Unleashed network, search the IP address of your Switch>open a browser and paste the Switch IP address Monitor>Device
Note: you can use the next guide to find the Switch IP address:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-find-my-Ruckus-Devices-IP-address-using-free-applications/td-p/47027
Is this what you are asking for?
And to answer your questions...
My Switch is online, but from Unleashes is displayed as disconnected (as in the image I sent you);
We have ATT as a provider. And there is no issue accessing internet when connected to ATT wifi.
But when connecting to Ruckcus access points I am often timed out trying to navigate to sites like cnbc.com, dell.com... All access points are online. Not sure if they works as expected because I am having all the issues accessing internet. I did reboot both switch and access points several time already.
I do not feel comfortable sharing my IP address on a public forum.
And WIFI signal strength from AP is fine
OK, so if the next are your Symptoms, seems the Switch start booting from the incorrect partition, let me add the Guide to solve the issue, please read the guides carefully before start the troubleshooting.
Symptoms:
Websites not loadingDevices getting disconnected or having problems working as intended.Network dropping at random points in time.Smart devices not being able to connect to the internet.Unleashed dashboard sometimes as “Disconnected” on the Internet tab.
Note: your IP address will be always local, so is not routable over the internet, this is why you have your ISP router in the middle to convert those IPs address in your home to an internet IP Address or routable over the internet.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issues-on-Lennar-Home-users-via-Web-GUI/td-p/47959
Follow up the Guide I have provided, you will be able to fix the issue.
I cannot connect to that IP neither via WIFI nor with the cable. As it shows in the image "Failed to ping 192.168.1.70
Follow up the Guide, while your computer is directly connected to your ICX 7150 Switch with an Ethernet cable, Use one of the yellow ports in the Switch.
I do have my laptop connected to one of those ports. I can connect to https://192.168.1.238/admin/dashboard.jsp fine. But I cannot connect using switch IP 192.168.1.70
I have the same issue, I have tried connecting the console port to my pc and mac both did not recognize the switch after installing the proper driver. Please advice.
Im having a similar issue. We had to shut power off while having some electrical work done and now the switch shows disconnected. How do I reconnect it?
Eduardo, did you fix this problem? I think I have same issue on my side and I am not sure how to fix it. My switch also showing disconnected.
Hi @jasminkoplje
Hope you are doing well
As this case is raised by @EduardoC which is very old and closed now.
To avoid confusion with posts, you can create your own post with the problem you're facing and a detailed description of the network issue and what you've done so that we can guide you properly.
