Hi Lennar Ruckus support team,
This seems to be a recent common issue as I can see other forum posts are encountering the same issue - just this past weekend my main Ruckus Switch and (3) ceiling access points keep power recycling. My Ruckus WiFi network will be available for a couple minutes before everything shuts off. The access points will turn completely off with no lights, the main Switch will have a solid green, but the syst light will alternate between flashing orange, solid orange, and solid green (for the short time it does remain working). The Ethernet port lights will be off when the access points are shut off as well. Then everything will cycle back on again before it shuts down after just a few minutes. The ruckus WiFi connection just won’t hold longer than 5 min at a time, but the main wifi from the router will, so the ruckus system as a whole is malfunctioning.
MAC: C0: C5: 20: 96: D9 BB
Can you please assist in getting an RMA started?
