Hi, My switch is ICX 7150-C12P. After power outage, It is showing Amber/Orange light on "SYST" and Green light on "PWR" & NO lights on APs. I have tried to reset, while powering on. It keep stuck at booting with orange lights flashing, I searched forum and tried to perform the software recovery using windows laptop. I am stuck at connectivity with switch shows "not live". Not sure what to do. I really appreciate if you can help me fix the issue or approve RMA.
Thanks,
Nishanth
