Hello- My Ruckus switch is not booting up after power outage. I see the power in green light but the internet line is amber in color. Tried to reboot multiple times by switching power on and off but of no use.
Hi Manjukusam,
Seems like the switch is stuck in boot mode. Kindly try below:
1-Please try to disconnect from the Power outlet the ICX-7150 and reconnect it.
If this step doesn't work, we need to perform a software recovery.
If the above does not help, You can use below link to log a ticket:https://support.ruckuswireless.com/contact-us
Nidhi
