This guide will explain, in details, how to disable two parameters that will cause that your Sonos devices can't pair with each other.
Command
Explanation
set qos eth0 directed multicast disable
This prevents the WLAN from converting multicast traffic to unicast.
qos directed-threshold 0
disable the multicast and broadcast threshold.
— Requirements:
*SSH client access (Putty on Windows, macOS command Terminal, or Linux terminal).
*Download putty for Windows computer.
https://putty.org/
*For macOS, you will use the terminal app integrated into your MAC.
Enter the next command from the MAC terminal for SSH access
Format
ssh <unleashed user>@<IP of the master Access Point>
Example
ssh admin@192.168.1.1
*Or from Windows open Putty and add the next information, then hit open
Note: the credentials for the CLI access to the master Access Point are the same credentials you used for the APP or the Web GUI
1: Using your SSH client application such as a putty or MAC terminal, gain access via CLI to the AP Master Unleashed.
2: Now enter the credentials:
Enter the username and password
You should be at the command prompt
ruckus>
Enter the following command: enable
ruckus>enable
ruckus#
Enter the command: config
ruckus#config
ruckus(config)#
Enter the command: show wlan
ruckus(config)#show wlan
Enter the command: wlan home-WiFi
Replace home-WiFi with the name of your Wi-Fi SSID
ruckus(config)# wlan home-WiFi
ruckus(config-wlan)#
Enter the command: no qos directed-multicast
ruckus(config-wlan)# no qos directed-multicast
Enter the command: qos directed-threshold 0
ruckus(config-wlan)# qos directed-threshold 0
Enter the command: end
ruckus(config-wlan)# end
This will save the changes.
Now restart your SONOS components
