Hi, I am unable to reset ICX7150-C12 after power outage... Lights flash amber continuously and no power goes to Access Points in home. I am unable to console connect to switch using a MAC. Requesting help here. Thank you
Hi @Rayoub
Hope you are doing well!!!
As per the case description, I could understand that you are unable to reset your RUCKUS ICX-7150-C12P Switch which is flashing amber continuously after a power outage and Access Points have no power.
As you mentioned there are amber lights flashing. Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
As you mentioned that you tried resetting, once again we will try to reset the Switch as described below:
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-D3B5DB74-53A7-4F8D-82F9-6EB600879EE7.html
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/td-p/47483
Please use a Windows laptop/PC for the software recovery process as there are some issue with MAC device.
thank you Imran I will try the reset multiple times. I have done it about 5 times so far. I do not have a windows laptop available currently. is there another way to perform software recovery?
Using Windows Laptop would be easier for the software recovery process.
However, please try to reset the Switch as mentioned in my previous post and let us know if that works. We will proceed accordingly.
thank you Imran after about 10 resets the switch turned on and is now powering my access points.
Is there any steps I can take to prevent this from happening in the future?
Thank you.
I am having same problem. Syst light is amber and have no power to devices. I tried to recover software but can’t figure it out. Is there any other way to get help doing the software recovery?
thanks
Hi @Ch823
Greetings of the day,
As this case was raised by @Rayoub
To avoid confusion please open a new case explaining all the detailed description of the issue.
admin test
Hi Irman - I am having the same issue and have serached this community formum, but do not have a PC either to follow detailed steps on KB articles. I have an older macbook. Can you share me the steps to rest my mac switch.
Cause: ISP power loss for 1 day, regained power, but swtich is stuck in boot mode I believe.
Issue: Amber SYST light, Green PWR, 2 AP receive no power
Tried resetting with power cycle and paper click while replugging 20+ times.
Previously I could jump on a call where someone could remote control and re configure the settings. Do you still offer this. Let me know next steps. Thanks!
Hi @jason_simek
Thank you for contacting the RUCKUS Lennar Home Community.
As this case/post was raised by a different Lennar RUCKUS user and is now closed. To address your inquiry, please submit a new post on the RUCKUS Lennar Community Portal by selecting the 'ASK the Pack' option. You can access the portal using the following link:
When creating your post, please include a detailed description of the issue and specify any troubleshooting steps you have already undertaken.
We appreciate your cooperation and look forward to assisting you.
