Have a power Outage and my AP's are not powering up. I have access to SWITCH ICX7150
Hi @Swarupbade
Thanks for your reply,
Based on your description, it shows that PoE is in disabled state. Please follow the below steps to enable PoE.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-enable-PoE-or-gather-the-logs-in-case-there-is-a-failure/m-p/49945
Please try unplugging and plug the AP which is blinking red. If this step doesnot work please perform a factory reset, let me add the steps, if the Access point still not responding, please reply with a picture showing that the PWR is red.
https://support.ruckuswireless.com/articles/000012418
Please follow the below link to perform the upgrade of your switch.
To upgrade your switch to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin, please perform the software recovery using the code 08090k with the upgrade image file named SPS08090k.bin, then when the switch is back to normal upgrade to the file SPS08095gufi.bin for both partitions primary and secondary.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-Switch-ICX-7150-C12P-using-a-USB-flash-drive/td-p/46781
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-Switch-ICX-7150-C12P-via-TFTP/m-p/47187
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-an-Upgrade-via-Web-GUI-ICX7150-Switch/td-p/48200
Greetings of the day,
1-On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on?
2- Make sure it is plugged into a well-known outlet/power source
it's green, i just confirmed
My switch is ICX 7150-C12P
based on pic you sent, I have 7 (Sys) and 16 (PWR) both Green. The only issue is with the Access point not receiving power. I see that ring which is connected to one of the ports in the switch is working. Also, I am sure the ATT router internet is working, as I am currently using it. Please let me know how to power up the AP. Thanks.
telnet@ICX7150-C12 Switch>enableNo password has been assigned yet...telnet@ICX7150-C12 Switch#show versionCopyright (c) 1996-2017 Brocade Communications Systems, Inc. All rights reserved.UNIT 1: compiled on Aug 14 2017 at 06:54:44 labeled as SPS08061a(24723488 bytes) from PrimarySW: Version 08.0.61aT211Compressed Boot-Monitor Image size = 786944, Version:10.1.10T225 (mnz10110)Compiled on Sun Jun 25 09:25:15 2017
HW: Stackable ICX7150-C12-POE==========================================================================UNIT 1: SL 1: ICX7150-C12-2X1G POE 12-port Management ModuleSerial #:FEK3204P0WHCurrent License:P-ASIC 0: type B160, rev 11 Chip BCM56160_B0==========================================================================UNIT 1: SL 2: ICX7150-2X1GC 2-port 2G Module==========================================================================UNIT 1: SL 3: ICX7150-2X10GF 2-port 20G Module==========================================================================1000 MHz ARM processor ARMv7 88 MHz bus8192 KB boot flash memory2048 MB code flash memory1024 MB DRAMSTACKID 1 system uptime is 20 hour(s) 43 minute(s) 17 second(s)The system started at 00:02:05 GMT+00 Sat Jan 01 2000
telnet@ICX7150-C12 Switch#show inline power
Power Capacity: Total is 124000 mWatts. Current Free is 124000 mWatts.
Power Allocations: Requests Honored 0 times
Port Admin Oper ---Power(mWatts)--- PD Type PD Class Pri Fault/State State Consumed Allocated Error--------------------------------------------------------------------------1/1/1 Off Off 0 0 n/a n/a 3 n/a1/1/2 Off Off 0 0 n/a n/a 3 n/a1/1/3 Off Off 0 0 n/a n/a 3 n/a1/1/4 Off Off 0 0 n/a n/a 3 n/a1/1/5 Off Off 0 0 n/a n/a 3 n/a1/1/6 Off Off 0 0 n/a n/a 3 n/a1/1/7 Off Off 0 0 n/a n/a 3 n/a1/1/8 Off Off 0 0 n/a n/a 3 n/a1/1/9 Off Off 0 0 n/a n/a 3 n/a1/1/10 Off Off 0 0 n/a n/a 3 n/a1/1/11 Off Off 0 0 n/a n/a 3 n/a1/1/12 Off Off 0 0 n/a n/a 3 n/a--------------------------------------------------------------------------Total 0 0
telnet@ICX7150-C12 Switch#show inline power detail
Power Supply Data On unit 1:++++++++++++++++++
Power Supply Data:++++++++++++++++++
Power Supply #1:Max Curr: 2.3 AmpsVoltage: 54.0 VoltsCapacity: 124 WattsPoePower: 124 Watts
POE Details Info. On Unit 1 :
General PoE Data:+++++++++++++++++
--More--, next page: Space, next line: Return key, quit: Control-c
ICX7150-C12 Router>
Show version
Show inline power
Show inline power detail
Based on your comment" ased on your description, it shows that PoE is in disabled state. Please follow the below steps to enable PoE."
I enabled all the steps, but still do not have power in APs. am I missing something? or let me know what I need to do. Thanks
SW: Version 08.0.61aT211Compiled on Aug 14 2017 at 06:54:44 labeled as SPS08061a
Yeah! my AP are back online. Please let me know if I need to update my drivers. Thanks
Please confirm if I am running the latest version
Moreover, only 2 of the 3 APs are back online and green. One of them is still blinking Red, any solutions to make it work??? Thanks
Unplugging and plugging back worked! Thanks
Please let me know how to update the drivers / software for the switch and APs to ensure I am using the latest version. Thanks.
I just downloaded the App and updated the latest firmware for the AP's, But, how do I update the Switch Firmware??
AWESOME, Thank you!!!
