Similar to past and recent posts, after a power outage, the switch has a steady green light for power and steady amber light for system, no power to the 3 Ruckus AP.
I followed previous solutions to hard reset (using a pin) and if no image to boot to try to load one. Unfortunately, while I was able to communicate a few times, result was that it was "not alive" - similar to this post: https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Switch-in-boot-mode-after-power-outage/m-p/54131
I tried it again today and it appears to be worse - see below. It seems to stay on the last "Releas321t>23" for a very long time (at least 10 minutes) until I hit enter and it gives me the ▒▒. It does not allow any commands and continues to repeat ▒▒ and delete itself before starting again. Same thing happens when we tried to reset again.
Please advise of next steps.
Ruckus Wireless Bootloader: 10.1.15T225 (Jan 30 2019 - 23:08:47 -0800)
Booted from partition 1 DRAM: Validate Shmoo parameters stored in flash ..... OK
ICX7150-12 (POE), PVT1
SYS CPLD VER: 0x4 Released Ver: 0xa
Writing Shmoo values into flash .....
device 0 offset 0xbfe00, size 0x200
device 0 offset 0x0, size 0xc0000
bootdelay: ===
Booting image from Secondary
NAND read: device 0 offset 0x4000000, size 0x2000000
8 ecc_errors after reading 5b48000:5b49c00
iproc_nand_read_page returned 2
NAND read from offset 4000000 failed -22
0 bytes read: ERROR
## Loading kernel from FIT Image at 70000200 ...
Bad FIT kernel image format!
ERROR: can't get kernel image!
could not boot from secondary, no valid image; trying to boot from primary
BOOTING image from Primary
NAND read: device 0 offset 0x0, size 0x2000000
8 ecc_errors after reading 1b48000:1b49c00
NAND read from offset 0 failed -22
0 bytes read: ERROR
ICX7150-Boot>23:08OK
Unknown command '23:08OK' - try 'help'
ICX7150-Boot>
ICX7150-Boot>
ICX7150-Boot>
ICX7150-Boot>ICX7150-12 (POE), PVT1
Unknown command 'ICX7150-12' - try 'help'
ICX7150-Boot>
ICX7150-Boot>SYS CPLD VER: 0x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>S YS CPLD VER: 0x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0 x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Releas321t> 23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Releas321t>23:08Ott>tt>IC X7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE) , PVT1tt>SYS CPLD VER: 0x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS C PLD VER: 0x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 R eleas321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Releas321t>23:0 8Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Releas321t>23:08Ott>tt>ICX715 0-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE), PV T1tt>SYS CPLD VER: 0x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Releas321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Relea s321t>23:08Ott>tt>ICX7150-12 (POE), PVT1tt>SYS CPLD VER: 0x4 Releas321t>23<INTERRUPT>
ICX7150-Boot>
:t▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒t>
Additional Attempt:
bootdelay: ===
Booting image from Primary
0 bytes read: ERROR
could not boot from primary, no valid image; trying to boot from secondary
BOOTING image from Secondary
0 bytes read: ERROR
ICX7150-Boot>
ICX7150-Boot>
ICX7150-Boot>
ICX7150-Boot>
ICX7150-Boot ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒
