After an outage in the area my Wi-Fi has been running really slow. I need help getting it back to its AMAZING speed that it used to be. Thanks šš¼Ā
HiĀ JRent
Thank you for contactingĀ Lennar Home Community.
Hope you are doing well!!!
From the case description, I could understand that yourĀ Wi-Fi is running slow after an outage.
This issue may happen when the Switch start running on the Routing code. The Switch should run on the Switching code to avoid these issues for Lennar home users. Due to a power outage the Switch boots up on the other partition which may be running on a āRouting Codeā results in causing this issue.
You can take Console access to the switch in order to verify, if the switch is able to connect properly to Access Points or if it has a āRouting Codeā issue which happens due to power outages most of the time, this is a known issue for Lennar home users.
-MAC address: Physical address of the device this never changes
- An IP address is a unique address (logical) that identifies a device on the internet or a local network like your home (this can change and may not be the same as the one shown on the dashboard)
Please follow the below steps:
I will leave you a guide on how to perform an IP scanner on your local network to identify the switch IP address very easily.Ā
How to find my Ruckus āDevices IP addressā using free applications:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-find-my-Ruckus-Devices-IP-address-using-free-applications/td-p/47027
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-remotely-access-to-ICX-7150-12P-or-access-points-quot/td-p/47388
ICX7150-C12 Router>
show version
copy flash flash secondaryĀ
boot system flash secondary yesĀ
Ā
(Please share the output screenshot of the āshow versionā command)
Example:Ā
ICX7150-24P Router>enable (hit enter to accept the command) ICX7150-24P Router#copy flash flash secondary (hit enter to accept the command and wait: until the flash finished) ICX7150-24P Router#boot system flash secondary yes (hit enter to accept the command: the switch will reboot)
There are Two ways to fix this issue:
I) How to Fix Routing code issues on Lennar Home users via CLI
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issues-on-Lennar-Home-users/td-p/47305
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-solve-the-routing-code-issue-in-your-ICX7150-Switch/td-p/47335
II) Or WEB access option
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issues-on-Lennar-Home-users-via-Web-GUI/m-p/47959#M1998
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-console-in-the-ICX-7150-12c-using-a-Windows-Machine/td-p/46759
Once you are logged in to the ICX-7150-C12P please follow up the same steps that are on point '3'
Too much information for me to understand. Is there any way I can speak to someone that can help me fix the issue?
I truly Apologize for the inconvenience.
Effective Novemberā2022, āRuckus Support for Lennar Homes customers will no longer be handled by phone or email.Ā We will be exclusively supporting customers via this community forum support model.
We have tried to create the guides as non-technical as possible, so that they are not much difficult to follow. However, if you continue to have difficulty following the steps,Ā I would recommend that you seek outside help or a technician.
Please do let us know if there is any help required on the troubleshooting steps or if you are stuck at any point. We are happy to help you.
I have the IP address but donāt know how to access the Command Line.Ā
