hello
I am trying to solve the problem by recovering the software after reset the ruckus.... green ligths on syst and pwr... I ALREADY INSTALLED PUTTY... i HAVE THE FILES BOOT AND IMAGE ON MY COMPUTER...wHAT i HAVE TO DO NOW?
Hi @jadelamain
Based on your description, it seems that the switch is stuck in boot mode.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-Switch-ICX-7150-C12P-via-TFTP/m-p/47187
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-an-Upgrade-via-Web-GUI-ICX7150-Switch/td-p/48200
It was not necessary... I just saw on youtube how to config powerlines in a range of ports...
The power was off on all off them. After config its ok and working well. I checked using the comand show powerline.
It is nice to hear that the issue is fixed.
What sight did you go to allowing you the steps to fix this issue. I'm running into the same issue. I have been trying to switch the com ports and have been unsuccessful. What steps did you do in order to fix your Ruckus?
As you mentioned, the SYST and PWR lights are steady green, which means the lights are in a normal state.
Since the switch is in the normal state you can take Console access to the switch in order to verify, if the switch is able to transfer the power to PoE devices via 12 ports.
To check this, first, we have to get access to the switch, and there are two ways to get access to the switch.
ICX7150-C12 Router>
Show version
Show inline power
Show inline power detail
Once you are logged in to the ICX-7150-C12P please follow up the same steps that are on point '2'
